ARC536Pro not seeing fav lists
Markb
Planet Earth
Hello.
I have been using ARC536 for a long while now. Not sure what I did exactly when this issue started, but when I plug in my radio (436, 535 or SDS), It shows that the radio is connected (shows very old FW version which is incorrect), but none of the fav lists poupulate on the download window. I have changed the drive to E:\ and renamed it to BDCx36HP. Still no luck and the test drive file shows the e:\ drive with no name. Tried re-installing the drivers as well.
I attached what what the bottom bar shows and here is the test drive file :
Code:
ARC536
b: [RECOVERY]
c: [OS]
d: [STORAGE]
e:
j:
k: [Seagate Backup Plus Drive]
E / 0 / E:\BCDx36HP\scanner.inf 69
F / 76 / F:\BCDx36HP\scanner.inf 70
G / 76 / G:\BCDx36HP\scanner.inf 71
H / 76 / H:\BCDx36HP\scanner.inf 72
I / 76 / I:\BCDx36HP\scanner.inf 73
J / 71 / J:\BCDx36HP\scanner.inf 74
K / 76 / K:\BCDx36HP\scanner.inf 75
L / 76 / L:\BCDx36HP\scanner.inf 76
M / 76 / M:\BCDx36HP\scanner.inf 77
N / 76 / N:\BCDx36HP\scanner.inf 78
O / 76 / O:\BCDx36HP\scanner.inf 79
P / 76 / P:\BCDx36HP\scanner.inf 80
Q / 76 / Q:\BCDx36HP\scanner.inf 81
R / 76 / R:\BCDx36HP\scanner.inf 82
S / 76 / S:\BCDx36HP\scanner.inf 83
T / 76 / T:\BCDx36HP\scanner.inf 84
U / 76 / U:\BCDx36HP\scanner.inf 85
V / 76 / V:\BCDx36HP\scanner.inf 86
W / 76 / W:\BCDx36HP\scanner.inf 87
X / 76 / X:\BCDx36HP\scanner.inf 88
Y / 76 / Y:\BCDx36HP\scanner.inf 89
Z / 76 / Z:\BCDx36HP\scanner.inf 90
[ / 76 / [:\BCDx36HP\scanner.inf 91
D / 0 / D:\BCDx36HP\scanner.inf 68
Thanks!
ofd8001
Louisville, KY
Things I'd be tempted to try to rule out some issues are:
1. See if Sentinel will read the scanner, which would confirm there is good communication between the scanner and the computer. If that works, without disconnecting anything, I'd shut down Sentinel and start ARC and do a read from scanner.
2. If I couldn't get the above to work, I'd try removing the SD card and put it in a card reader on my computer, and use either Sentinel or ARC to read. That would rule out any cable, connector or com port issues.
