This is really frustrating!
I went back and removed all of the SK's from all of the systems (30+) that I had originally had SK's on.
I then sent them to the scanner and they worked as they should. But then I created an new database with other conventional systems that were not included with the database that had the 30+ systems and loaded that database into the scanner and it now show "Nothing to Scan" but with the QK's enabled (on the scanner screen). It seems like the scanner is holding on to the original programming and not allowing any other programming to work.
The Easier to Read manual says this about using Startup Keys:
"Caution: If you press the wrong key when you press the power key to set your startup configuration, and that wrong key doesn't have any systems assigned to that key, you will startup your scanner with all systems locked out. You can't start Key-Safe mode and Startup Configuration at the same time (i.e. Power+Func+Startup Key). Also, you can't cancel Startup Configuration, i.e. have your scanner startup with all systems unlocked they way they were before you used a Startup Configuration (unless you reset your systems, sites, and search ranges to 'no startup key')."
I have done a reset 2 times (2,9,Hold and power on), but it doesn't seem to make a difference.
And, as I said above, I turned off the SK's on everything. No sites because these are all conventional channels.
Is there a deeper reset that wipes the whole memory (including the States programming)??
J
