Just where are you located in Massachusetts? I am in Gardner northern Worcester County and am wondering if 700MHz is available near mer. I am almost 1300 feet above sea level and should be able to hear into Boston and Pioneer Valley locations. Just don't want to update if there is nothing to monitor.
Where in Gardner is 1300'? I can take a ride over to the general area to see what I can rx.
I live here also and have not had a sniff of the 700 in the last X number of years with the 436. That being said, in one small part of Fitchburg (not in the hills, either) I did get a sniff of it with the SDS100. On occasion at home I get the Warwick site for the W. Mass P25, and I get it a bit more with the 100.
I haven't had enough time with the 100 on the road in the area yet, but I'm having some rx issues on both the analog MSP system and the Worcester P25 system. Basically it's not performing as well as I had hoped. There are still dead spots (or simul interference spots) on Rt 2 in Westminster on the MSP system and Worcester is weirdly hot or miss in some areas. The 436 will grab some transmissions the 100 will grab some transmissions and both will grab some transmissions.
Right now, I wouldn't get a 100 for home. This far away from the 700 system, I don't know how much simulcast interference there would be all the way out here so you may get it on a 436. While Worcester technically is TDMA, only Emg Management currently have TDMA talk groups.
