Providing a feed via BCD536 wifi
bill11312
Brewster, NY
Hello,
I am looking for some information on whether or no I could set up a Scanner feed in my area strictly by using the WiFi via the BCD536 ? I can use the Siren App but I would like to use the WiFi directly. Thanks in advance.
ProScan
Software Provider
Ontario, Calif.
Hello,
In addition to jonwienke advising on my ProScan. My FREE RadioFeed app also can use the scanner Wi-Fi to stream audio and text tags. Just no remote control and virtual display.
W4TF
FL
Bob, I followed your directions to setup proscan to steam via WiFi (no audio cable between radio and pc). Are you saying that I could now use RadioFeed to stream to Broadcastify/RR with this setup? I tried, but it seemed like RadioFeed was looking for an actually cable input for audio, not WiFi. How do I tell RadioFeed to use the WiFi audio?
Sent from my SM-N950U using Tapatalk
ProScan
Software Provider
Ontario, Calif.
Yes. Go to the Input Sound Device box, select URL then click the URL Setup button.
W4TF
FL
Thanks for the quick reply. The only option I have in the drop down is "Primary Sound Capture Device", url is not a listed option in my RadioFeed app.
Nevermind, I just realized I could do this directly from ProScan. Thanks again for the help and incredible write up
Edit: nevermind, I just realized I could do this directly from ProScan. Thanks again for the help and incredible write up
NYRHKY94
Brunswick County, NC
W4TF:
Under the Metadata tab in RadioFeed, do you have BCD536HP selected as the scanner type? Once you do that, URL will appear as an option under sound input
NYRHKY94
Glad you enjoyed my write-up. Bob was nice enough to work with me on those tutorials and then post them on his main web page. Using the Wifi feature for feeds provides the best audio of any method I've used to date.
W4TF
FL
Nope, I did not. Now I see it. But I just realized I could broadcast directly from ProScan, so I'm going that route. Thank you nonetheless. Amazing software!
