In need of XPR7350 codeplug
celestis
Decommissioned Nextel Site
Bought an XPR7350 on eBay used, got it and tried to read it in CPS... it's password protected. Contacted the seller, he tells me it came from a defunct LMR vendor and he doesn't now how to approach getting the password. Could someone PM me with a codeplug I can write to it? Model number is AAH56RDC9KA1AN.
Thanks in advance
rbrtklamp2
Dupage County, Illinois
Well if it's not functioning open a case and get your money back. Password protection is making the item unusable get your money back and buy another just make sure to ask if it's password protected before you buy. Something sounds a little off when he says he doesn't have the password you may have a stolen radio.
Sent from my SM-N910V using Tapatalk
celestis
Yeah, I was planning to do that soon if I couldn't get this unit working
KG4INW
Midlothian, VA
Just download and install the latest firmware from MOL, connect the radio to CPS then click on Device followed by Recover. Follow the prompts that appear. This will make the radio "factory fresh" and allow you to program without a password as it wipes clear the current codeplug (will take a few minutes, just be patient). I just had to do this week before last when working on a customer's radio that wasn't purchased from us.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Alternatively, you can perform a recovery on the radio. Requires the same or newer firmware than the radio currently has be installed on the programming machine. TT
