The reason Bluetooth isn't built in is because it generates RFI that interferes with reception. Your only other option is to use a patch cable between the scanner and Bluetooth transmitter that has ferrites on it to block RFI from traveling down the cable, and get the Bluetooth transmitter as far from the scanner and antenna as possible.
