tracking truck radios
radioguy32
I have a variety of XPR radios in our snowplow fleet of 30 trucks. Management wants to track the trucks to make sure each road gets plowed. What is the resolution if I use the radio? i.e. How many data points would I see? Do I get 1 point every minute? That is not good enough. That might work on a highway hauler but we need higher resolution. What do I need to look for in a solution?
N1GTL
CT
You need a third party application to do the GPS tracking.
I've put three NeoTerra systems in that do just this. They have an XL Box that will store way points every x seconds (I used 5 seconds). You will not get real time every 5 seconds but about once every few minutes, the boxes will upload the breadcrumb trail to the map. Real time you can expect one minute updates. You can then go back and look at the history and see every 5 seconds.
The bigger system I configured tracks about 150 vehicles. Because of the amount of vehicles, it is a single site Capacity Plus with a voice repeater and a data repeater. It uses ARS so the trucks register and unregister when they start and stop. They're out of Canada, tech support is pretty good.
That's about as good as you will get using TRBO. The other option is GPS's with something like TrackStar.
Firebuff880
Boynton Beach, FL
PM me with your contact data. Be happy to talk with you about your application. While the separate box would certainly do this for you, we should be able to do the same thing using the Generic option board, support relays for plow up an plow down as well as spreader on off. Lastly, you should consider Emergency and if you trucks are lone operators man down alerts.
