Received my SDS100 a few weeks ago & it was preforming great, excellent reception w/o missing virtually any transmissions. Took it on a trip to another area & setup the local FD's using the zip code search feature & got excellent performance. Came back home, turned back on my FL list for my local area, now it's hit & miss reception. Signal strength bars all over the place while the scanner sits in one spot, missing transmissions (as compared to my G5,) seems like it lost it's great sensitivity. All I did was remove the antenna, pack in the suitcase & use the nationwide database. Could have removing & reinstalling the antenna somehow damaged the connector? I'm getting fair reception, but not great like before but had already switched to a 700 MHz antenna using the enclosed bnc adapter after I received the scanner. Thought it may be the antenna so switched back to the standard antenna supplied with the unit & no change in the now less than great reception. Any suggestions please?
