this is interesting info, thank you for sharing. i understand the FAT structure limitations now as some of you have mentioned.
theres a few things i do to deal with this, but i still get crashes, usually 1 of my 7 436/536HP units will crash a day, so over the course of a week i might have 3-5 crash. i use a program called wondershare for file recovery and it works great most of the time. as soon as i realize a crash has occurred i pull the card and recover the lost directory, plus any other session directories that were not affected by the crash. i keep a holder with about 7 SD cards pre programmed ready to go, particularly handy on road trips. most of my cards are 16-32GB and they all have the potential to crash the same as the mentioned 2GB so the fat thing makes sense.
i keep a master image that i update and change when needed containing all my pre configured sessions.
i edit each session summary file for maximum recording by changing the 600 second reference to either 9999 or 99999, this really works well.
some sessions, i lock out the really common dispatch channels so it can take the time to hear less common talkgroups. then other sessions have some of the dispatches and i rotate sessions of scanners dedicated to the trunked system usually on a daily basis.
the discovery mode file structure saves me SOOOOOOOOOOOOOOO much time because if i record the non discovery way, it just dumps all talkgroup audio in to bulk directories which require me to transfer all those individual files to a single directory, then sort them by tag, then create sub directories for every talkgroup. discovery eliminates ALL of that. i prefer discovery for the way i am storing files but i understand that might not work for some, but i think if more people understand how it sorts all the talkgroup audio easily they might use it more with edited session summary files.
as 436HP units get cheaper, i plan to add more to my collection for 24/7 recording and if i can find a good deal on a SDS100 i will eventually pick one up
