I am noticing that sometime the SDS100 will drop out in middle of a transmission. This happened in both digital and analog. I have seen "link" in the top of the display. Anyone else notice this happening?
Tim
Tim
Tim
The latest beta was just installed which finally allowed reception of NXDN. Problem occurred before update as well. It does not happen on my 436
Tim
Tim
Tim
While monitoring and holding a conventional 440 Ham frequency the SDS100 is now cutting out occasionally during the transmission while "link" is flashing so am having same issues as OP.
All settings for the Ham frequencies in Sentinel were regular FM for modulation but under Audio Option I notice audio type set to "all". I now do see choices for analog or digital along with the digital option button checked. I will select analog only to see what happens for that one particular frequency I noticed it on.
If that corrects the issue will each individual frequency need to be manually changed ?
Wow.......if that's the case that is a bit cumbersome for numerous frequencies. But let's not jump to conclusion yet...............lets see if it continues.
OK. Care to elaborate? My SDS100 received and decoded NXDN fine since the original firmware...
What settings are programmed for the channel? "Link" is an indication the scanner is hearing a P25 data transmission over a voice channel.
What settings are programmed for the channel? "Link" is an indication the scanner is hearing a P25 data transmission over a voice channel.[/QUOTE
Adjustments were made for the issue I was having on Ham bands but questions remain as to why scanner is hearing P25 data transmissions on voice channels in places where there isn't any P25. As I said earlier I never had to program hp436 that specific to each frequency and a lot of values were left at default and the scanner chose what was best. Have not had cutting out occur on that specific frequency since changing but have had it occur other places.
