Larsen Tri-band antenna
A new design…
jfr
Walpole, Ma
How is that different than the original Larsen 150/450/800 other than a spring?
EDIT: Now I see larger bandwidth at UHF and inclusion of 700.
-JR
-JR
Bingo.
The original Larsen tri-bander started off as a scanner antenna. The original release had verbage saying "not for transmitting". A few years after it's release they started advertising it for transceiver use. Good for most stuff, but lacked in the 700MHz range. Now that there are so many multiband radios coming out, it was a good idea.
A lot lower profile than some of the other tri-band antennas.
K7MFC
WRAA720
Phx, AZ
Very nice! I would definitely upgrade my current Larsen tri-band when this is available.
bgav
Central MA
More information here:
Pulse Larsen Introduces a New Antenna
Pulse Larsen antennas will introduce the new NMO150450758 tri-band-monopole antenna to accommodate the Motorola APX™ 8500 mobile at APCO. This omnidirectional antenna will have vertical polarization and an NMO connector. The IP67 rated and RoHS compliant antenna will be economically priced, while covering 150-165/430-520/750-870MHz. A more flexible spring to allow for better environmental performance and durability that other competitive products in the marketplace.
AK9R
Super Moderator
Central Indiana
It's a spring/pin base rather than the tab contact. Also, is got the indentations, which make it easier to remove from the mount.
Ah, I see.
Spring/pin base? Isn't this a major departure for Larsen? The tab contact has been a Larsen feature for decades. Are they just copying other people at this point?
jfr
Walpole, Ma
@Mmckenna- if you’re at APCO this week, can you make a thread and post pics of all the goodies?!?![emoji38]
-JR
bgav
Central MA
What I'd really like to see is a Nickel Boron (NiB) or PVD/DLC finish as the black paint on both of my Larsen Tri-Bands is flaking...
Ah, I see.
Yes, I was talking to their guys about that.
They said there were two "camps", those that loved the tab base, and those that like the spring base.
I've never had a problem with the tab base antennas. I did have issues with the old spring base Motorola 800MHz antennas from the 80's and 90's, my understanding was that those were made for M by Antenex, maybe.
Either way, it was a nice looking antenna. Would be nice to see how it compares with the others.
-JR
I'll try. The expo floor closes tonight, and I've got a few sessions I need to be at in the afternoon.
Most of the big stuff had to do with LTE, LTE-LMR conversion, and of course, FirstNet. FirstNet has a pretty prominent booth.
Kenwood had their VP/VM line of radios on display. Some LTE stuff.
Motorola had their Haz-Lo APX radios.
Only one CCR company there, and it looked like they were pretty much getting ignored.
Hytera had a nice booth with some interesting tactical/portable DMR mesh type repeaters. Nice looking stuff. I think they are going places.
