spdfile1
/\/\ Junkie
I have an HT1000 16-Channel UHF (S split) that has super low audio on receive. When I swapped it out to replace the back battery plate I noticed there were two boards....a controller board & transceiver board. If I purchase an S split transceiver board off ebay (that is tested to work) that should fix my issue right?
I also have 2 MT2000's (VHF-K split) one partial keypad & one full keypad both with front displays & both with pixels that are so broken you really can't read them. If I purchase a couple used units on ebay with good pixel displays I can swap out the display boards right regardless of what band split they are?
