readout from DSD+
So for the channel that is transmitting the idle marker.. look at the data in DSD+ and it will say something like Idle Channel or Home Channel.. that would be what you are looking for.
Matt
THIS IS WHAT'S COMING UP ON 168.180 is the LCN IN THERE ?????
DSD+ 2.113
Writing synthesized audio to per-call mp3 files
Appending synthesized audio to file 'DSDPlus.wav'
Current working directory is "C:\DSD"
audio input device #1 = 'External Mic (IDT High Definiti'
audio input device #2 = 'Integrated Microphone Array (ID'
audio output device #1 = 'Speakers and Dual Headphones (I'
audio output device #2 = 'IndependentáDual Headphones (ID'
audio output device #3 = 'SPDIF (Digital Out via HP Dock)'
audio input device #1 (External Mic (IDT High Definiti) initialized
audio output device #1 (Speakers and Dual Headphones (I) initialized
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated; press Esc to exit...
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK ERR5 Cap+ RestCh=1
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR1 DCC=10 CSBK ERR12 ECC FAIL
+DMR slot1 BS DATA DCC=10 CSBK ERR3 Cap+ RestCh=1
+DMR slot2 BS DATA DCC=10 CSBK ERR1 Cap+ RestCh=1
Sync:+DMR
+DMR slot2 BS DATA ERR1 DCC=10 CSBK ERR7 [LB=1 CSBKO=41 (?)
FID=10 v16=0100 id1=17163 id2=16515072]
29 10 0100 00430B FC0000
10101001000100000000000100000000000000000100001100001011111111000000000000000000
1100000111010110
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=10 CSBK ERR9 ECC FAIL
+DMR CACH ERR slot2 BS DATA ERR2 DCC=10 CSBK ERR10 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR2 DCC=10 CSBK ERR11 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR1 DCC=10 CSBK ERR9 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK [LB=1 CSBKO=41 (?) FID=1
0 v16=0100 id1=2573 id2=16515072]
29 10 0100 000A0D FC0000
10101001000100000000000100000000000000000000101000001101111111000000000000000000
0101111101011011
+DMR slot1 BS DATA ERR1 DCC=10 CSBK Cap+ RestCh=1
+DMR CACH ERR slot2 BS DATA ERR1 DCC=10 CSBK ERR7 Cap+ RestCh=1
+DMR slot1 BS DATA ERR2 DCC=10 CSBK ERR10 ECC FAIL
CACH Sig ERR3
+DMR CACH ERR slot2 BS DATA ERR2 DCC=10 CSBK ERR9 ECC FAIL
Sync:+DMR
+DMR slot1 BS DATA DCC=10 Data Header ERR5 DPF=[15
rop
] SAP=1 MFID=16 1F 10 02 01 33 00 16 00 01 31 5D 3C
+DMR slot2 BS DATA ERR3 DCC=10 CSBK ERR3 Cap+ RestCh=1
+DMR slot1 BS DATA ERR1 DCC=10 Rate 1/2 Data ERR5 00 00 00 0
0 00 01 00 00 ........ CRC FAIL
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK ERR7 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA ERR1 DCC=10 CSBK [LB=1 CSBKO=41 (?) FID=1
0 v16=0100 id1=3853 id2=16515072]
29 10 0100 000F0D FC0000
10101001000100000000000100000000000000000000111100001101111111000000000000000000
0111110000001100
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK ERR6 Cap+ RestCh=1
CACH Sig ERR1
+DMR slot2 BS DATA DCC=10 CSBK ERR3 Cap+ RestCh=1
Sync: no sync
Sync:+DMR
+DMR slot1 BS DATA ERR1 DCC=10 CSBK ERR1 Cap+ RestCh=1
+DMR slot2 BS DATA ERR1 DCC=10 CSBK ERR5 ECC FAIL
CACH Sig ERR1
+DMR slot1 BS DATA ERR1 DCC=10 CSBK ERR3 Cap+ RestCh=1
+DMR CACH ERR slot2 BS DATA DCC=10 CSBK ERR6 ECC FAIL
+DMR slot1 BS DATA DCC=10 CSBK ERR5 Cap+ RestCh=1
Sync:+DMR
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 Data Header ERR7 DPF=[15
rop
] SAP=1 MFID=16 1F 10 02 01 11 4B 76 0D 1B 22 CB 8A
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR2 DCC=10 CSBK ERR13 ECC FAIL
Sync: no sync
Sync:+DMR
Sync: no sync
Sync:+DMR
+DMR slot1 BS DATA ERR1 DCC=10 CSBK Cap+ RestCh=2 ActiveCh:T
G=1:1
Sync: no sync
Sync:+DMR
+DMR slot1 BS DATA DCC=10 CSBK ERR1 Cap+ RestCh=2 Acti
veCh:TG=1:1
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR1 DCC=10 CSBK ERR14 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=10 CSBK ERR7 ECC FAIL
+DMR slot1 BS DATA DCC=10 CSBK Cap+ RestCh=2
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK ERR1 Cap+ RestCh=2
+DMR slot2 BS DATA ERR1 DCC=10 CSBK ERR2 Cap+ RestCh=2
+DMR slot1 BS DATA DCC=10 CSBK ERR3 ECC FAIL
Cap+ Site=1 RestCh=2
+DMR CACH ERR slot1 BS DATA ERR2 DCC=10 CSBK Cap+ RestCh=2
+DMR slot2 BS DATA ERR1 DCC=10 CSBK ERR3 ECC FAIL
Sync: no sync
Sync:+DMR
FID=10 v16=0201 id1=14421006 id2=16515072]
29 10 0201 DC0C0E FC0000
10101001000100000000001000000001110111000000110000001110111111000000000000000000
1101011001000001
Sync: no sync
Sync:+DMR
+DMR slot1 BS DATA ERR1 DCC=10 CSBK ERR4 Cap+ RestCh=2
Sync: no sync
Sync:+DMR
+DMR slot2 BS DATA DCC=10 CSBK ERR3 [LB=1 CSBKO=41 (?)
FID=10 v16=0200 id1=5902 id2=16515072]
29 10 0200 00170E FC0000
10101001000100000000001000000000000000000001011100001110111111000000000000000000
0010100111010010
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA ERR3 DCC=10 CSBK ERR9 ECC FAIL
+DMR slot2 BS DATA DCC=10 CSBK Cap+ RestCh=2
CACH Sig ERR2
+DMR slot2 BS DATA ERR2 DCC=10 CSBK ERR2 Cap+ RestCh=2
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=10 CSBK ERR10 ECC FAIL
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=10 CSBK ERR4 Cap+ RestCh=1
+DMR slot1 BS DATA DCC=10 CSBK ERR4 Cap+ RestCh=1
+DMR slot2 BS DATA DCC=10 CSBK ERR2 Cap+ RestCh=1
CACH Sig ERR1
Sync: no sync
Sync:+DMR
+DMR CACH ERR slot1 BS DATA DCC=10 CSBK ERR12 ECC FAIL
Sync: no sync
