Difference in reception from mag mount to roof mount
STEVE392
Bergen County,NJ
I am finally going to pull the plug and do a roof mount for my radio instead of using the magmount on my F150. How much of an increase in reception could I expect if any? I am using a yaesu ft-270r for a radio.
belvdr
No longer interested in living
If it will be in the same location as the mag mount, I doubt there will be any difference.
K5MPH
Brownsville Texas,On The Border By The Sea.
I have done the same over the years of being a ham for 29 years going from mag mount to drilling a hole and the only thing i really seen change was the dead spots and nulls around town you will get a better ground and acting ground plane hope that help you.....
Those are losses at 800MHz. I wonder how that translates to 144-148MHz, which is where the OP's radio lives.
The losses at VHF will be less, however the comparison between a mag-mount and a permanent mount will be the same. In other words, you'll see a 0.2dB improvement by going to the permanent mount alone.
0.2dB is unlikely to be noticeable on it's own.
Where you may see a better improvement….
-less coaxial cable to reach your radio since cable run can be more direct. No more running across the roof, through a window/door to your radio.
-less chance of damage to the coaxial cable. Cable getting pinched in windows/doors throws off the characteristic impedance of the cable. Damaged coaxial jacket will let water in and the corrosion becomes an issue.
-Proper grounding can make it easier to lower SWR. Lower SWR means more power gets radiated by the antenna. It can also reduce noise.
So, on it's own, installing the permanent NMO isn't going to result in a noticeable improvement. It's all the other changes that add up.
And then there's the pure aesthetics of it. Big difference in looks between a mag mount with the coax run across the roof and through a window and a professional looking install.
bob550
Albany County, NY
Unless it's not a concern for you, consider the affect of a hole in the roof on your F-150's resale value.
Zero impact on mine. 2 NMO mounts on the roof. I remove the whips and put on rain caps. I traded in the truck and got more than I was expecting for it because I'd put a lot of effort into looking after it and keeping it clean. Never at any point was their any word about the NMO mounts. It was a white 2011 F150, the rain caps were black. Not like they were hiding. In fact, rather than the truck going to a broker to be sold it stayed on their lot and was sold directly by them. I saw it a few weeks later, still had the black NMO rain caps on the roof.
I've had several family members trade in cars, trucks and SUV's with NMO mounts, no issues. Same with lease vehicles, no issues. Often they end up going to a broker, who buys them sight unseen and resells them to other dealers that want the specific models.
A properly installed NMO mount will not leak. If the buyer is concerned, put a rain cap on their, or get an old 800MHz antenna and tell them it for improving cell phone service. Or, just keep the truck and run the wheels off it.
I've never heard of the resale value of a vehicle being impacted by a properly installed antenna mount.
K7MFC
WRAA720
Phx, AZ
What depreciates the car more - an NMO hole than can be capped and look like a factory GPS antenna? Or a scratched up roof from 5 years of mag mounts going on and off?
RFI-EMI-GUY
It would be +$75 in my case,
Just today I was following a personal pick up truck with what appeared to be an NMO-27B on top. I was very pleased!
Sent from my SM-T350 using Tapatalk
gmclam
Fair Oaks, CA
I have 3 different mag mounts. They each have their own sets of pros and cons. Get an antenna tuned for the frequencies of interest with low loss coax and it won't matter how it's mounted.
STEVE392
Bergen County,NJ
I'm not worried about resale value. It was a lease that i bought out. Im just sick of the mount banging and constantly getting knocked off the roof, falling over the side doors and scratching the paint. I also want to get the wires out of hte door jam. It got pinched once and i kinda fixed it but im sick of trying to make sure they stay put whenever i get my son from the back. Permanent mount would allow me to route wires under the headliner and down the a pillar to the radio. With a proclip or panavise mount it will clean it up and open up my other cup holder lol
STEVE392
Bergen County,NJ
12dbsinad
The permanent NMO mount will provide a better ground plane for the antenna. The mount will also be grounded to the metal, this happens when you tighten the collar and the teeth "bite" into the underside. I think all and all you'll notice a difference out on the fringes. Also, don't worry about resale value, they don't care.
Eventually mag mounts will be a thing of the past with aluminum bodies, unless you're going to fab a steel plate above the headliner, or some other mod. A drilled in antenna mount is a happy antenna mount... and doesn't scratch the heck out of your paint.
STEVE392
Bergen County,NJ
Not worried about resale value. I put on 65k miles on my truck in 3 years, im already upside down on my loan vs value, lol. So i'll be driving this f150 till it falls apart or i win the lottery.
Off topic question, i tried searching but didn't see anything that could help. Will cellphone towers affect radio reception if you are within like 50 feet of the tower?
They can. Even on different bands, a strong signal from a cellular base station can easily overwhelm the receiver.
Think of being at a party. You are trying to listen to someone across the room who is talking quietly. Meantime there's a big guy who's had to much to drink talking really loud next to you. Makes it hard to hear the weaker signal.
12dbsinad
I hear ya.. welcome to vehicle ownership. The worst investment you'll probably ever make, depreciation on a vehicle is just astonishing.
It all depends on the frequency band. Typically, it usually isn't a issue on VHF. However, at only 50 feet anything is possible. A lot of cell sites use POE (power over ethernet) with what they call remote radio heads. Basically, the RF equipment is actually part of the antenna up on the tower to cut coax loss and number of feeds. POE can sometimes generate RFI garbage on lower bands depending on the quality of the units. It's really hard to determine weather one tower or another will interfere, given so many variables, what band, and what's on the site for equipment, and also the quality of your own equipment.
STEVE392
Bergen County,NJ
Thanks. I only asked since I go out railfanning i go to this one spot that is right next to a rather new cell tower. Ever since it was hooked up about 5 years ago (it had sat unused for years) radio reception where I go is horrible. Even with a perfect line of sight down the tracks, you can't hear anything outside of 2 miles away. I used to sit here before the tower and here on some days upwards of 50 plus miles to the north. Now just 2 miles if im lucky. Maybe its just coincidence.
