NXDN Data in RR
fdnyfish
Barnesville, PA
I see Pennsylvania Power Lighting (PPL) in a Digital Frequency Search for NXDN in Schuylkill County PA.
When would this info appear in the RR database for download to Sentinel?
Is this stuff happening automatically, or is it all user entered into RR.
I'm a little confused on how to get this into Sentinel as NXDN
PPL ELECTRIC UTILITIES CORPORATION 90FB2 IG - 150.875000 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 90FB2 IG - 152.292500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 90FB2 IG - 153.027500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 90FB2 IG - 153.312500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 90FB2 IG - 153.372500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50FX1 IG - 160.027500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 157.537500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 157.552500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 157.672500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 159.592500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 159.607500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None Off
PPL ELECTRIC UTILITIES CORPORATION 50MO IG - 159.892500 NFM NAC/Color Code Search Custom 1 Off 1sec Off Green / On 0 None
phask
KZZV - SE Ohio
EVERYTHING in the DB is user submitted for verification, nothing is automaticllyloaded from FCC files.
As to where - either under statewide or the county - but that data only indicates a liscenseto use that, not that they are, or even if they ever will.
Common to get a lic. for mulipleemmision modes, just in case.
scan-pa
RRDB Admin
Lebanon, Pa.
Once a system has been confirmed and submitted, with all the required info.., then it will be added to the DB.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
The license (WQYB864) indicates that it is a conventional (IG) license with 4 khz emissions (NXDN or IDAS). You are only interested in the "FB2" frequencies, as those are the repeater outputs. There is no guarantee the sites are online. And if they are online they may be conventional NXDN or NEXEDGE/IDAS trunked.
Regardless of whether they are conventional or trunked, if they are online and your Uniden scanner has the NXDN upgrade, there is no reason you shouldn't be able to hear them.
1. You've have to add them to a Favorites list in Sentinel manually
This is because they are not published in the RRDB because nobody has confirmed them to be online.
2. You should be able to just add them as standard NXDN channels with a wildcard RAN
This would allow you to hear anything on them if they do transmit (in the clear).
Mike
sibbley
Nazareth, Pennsylvania
If Schuylkill County is being used like Lehigh County, it could be a while before you hear anything. I don't remember if Lehigh was listed as conventional or trunked, but it seems to be used as conventional. Comms are few and far between.
scan-pa
RRDB Admin
Lebanon, Pa.
It is not online yet. There working on getting the Dauphin Co. / York / Lancaster system running. Then Berks / Schuylkill.
Sent from my SM-G935V using Tapatalk
fdnyfish
Barnesville, PA
Mike
Is the wildcard "0" ?
mtindor
OH/WV DB Admin
Sorry -- I guess you just set "Digital Code: Search"
If you choose an option for DMR Color Code, P25 NAC or NXDN RAN then you have to enter a RAN.
Under "Audio Options"
Audio Type: Digital Only
Digital Option: Digital Code Search
If you ever do hear anything on them, they will display the code (the RAN in this case). And once you know the RAN you can choose to set a specific RAN instead down the road.
Mike
