V1.1 upgrade
LEH
Yorktown, Virginia
I have downloaded the firmware and run the installation. When the 'Update Software' login appears, it will not accept the 'admin'/'admin' user name/password. (without the apostrophes)
sibbley
Nazareth, Pennsylvania
I had no problem. Accepted admin/admin. I'm up and running.
LEH
Yorktown, Virginia
Sibbley, did you do anything with the C++ portion of the installation? I am wondering if it might be something to do with that.
Also what version of Windows (or are you emulating through a MAC or Linux) are you using?
My 20 years in troubleshooting broke airplanes with the Air Force is showing.
us007605
Granger, IN
I uninstalled and reinstalled and did a repair of the C++. After a reboot it still tells me the username or password is nor correct. PPS Logs in fine as usual so just the updater that isn't happy.
us007605
Granger, IN
I tried again this time uninstalling both the updater and C++. Then ran the installer again and reinstalled both. Still giving the login error. Win 7 pro here as well. Also tried a fresh download of the installer from the website
Brian
u7string
Bel Air, MD
Brian
Same here. Running Windows 10 however.
belvdr
No longer interested in living
Ray posted on FB that they update server can take only so many logins at once, hence the issue.
I've been in constant thought on whether to get a Unication or SDS100. Things like this just add to the pile. It smells of a hokey support system.
LEH
Yorktown, Virginia
A post on the FB page says the login issue is the server being overloaded by all the hits to do the upgrade. Just keep trying, and trying, and...
jrj13
Fairport, NY
So is the solution to the password problem to download version 1.1 again and reinstall?
N6ML
Details are a bit sparse, but it sounds like the RemoteUpdater is trying to connect over the internet to a server at Unication, and that server is overwhelmed by us all trying to do it at the same time. If that's the case, it should not be be necessary to reinstall - just run the RemoteUpdater again later, and keep trying (periodically) until it gets past the "Login" stage
bgav
Central MA
You guys are DDoSing the server!
