Priority is a lost art that takes some patience to master as you build out your program, although I'm speaking from an old-school dynamic memory Uniden guy. I quite often run with 5 priority channels I listen to, and depending on the order they are programmed in, the highest priority channel can be determined. The blip takes very little audio out of the existing traffic, and I don't miss traffic that I've determined to be priority. These object oriented programming radios are taking a new art to get as efficient as possible, and Whistler priority is definitely hobbled compared to Uniden (dynamic memory, not sure how Uniden's newer Object based radios behave.)
What frustrates me with Whistler priority behavior:
1. There is no hierarchy to priorities like Uniden has, one cannot be more important than another. They're all treated equal.
2. There is no continuing of checking priorities when it is stopped on an existing priority channel. (which wouldn't be good anyway without the hierarchy mentioned in 1).
3. There is no checking of priority while held on a channel.
My BCT-15X sings a very efficient song as I travel throughout California, and I know wherever I go, depending on systems I have activated, CalFire dispatch for the area I'm in will be highest priority during fire season, with Highway Patrol as a 2nd priority (or swapped as lead during winter.) Then about 3-5 addl priorities are sampled. All regardless of being held manually on a channel etc. the priorities are checked, (and if I want a true hold, I can very easily turn off priority check from the keypad). If I get a hit on my "3rd" priority, it will still allow my "1st" and "2nd" priorities to override, but not 4th and 5th. I love it and my live scanner at
http://norcalscan.live utilizes this like a champ, and was able to cover the Carr and the Mendocino Fires at the same time, allowing me to steer exactly what fire had highest priority, which had second, etc.
My WS1098 now while mobile is pretty hobbled as I travel through CA. CHP and CalFire are still on priority depending on my location, but it's first-come-first-served only; whoever gets there first holds the radio until they stop transmitting. The 15X has twice the active audio coming out than my WS1098 due simply to the efficiency I can program the 15X instead of having my hands tied by the Whistler.
A lot of people here have Whistlers for base radios stationary and listening to trunked systems. Awesome. But these things quickly become inefficient and frustraing when mobile and traveling through an area where I can toggle on and off between 2500+ conventional channels and equal number of talkgroups depending on location.
