EastTroyDon
I currently run my Grundig 750 with an Alpha Delta SWL Sloper positioned from approximately 90 degrees to 270 degrees. I recently purchased a FRG-7700 and would like to run the Yaesu thru a secondary antenna positioned 90 degrees perpendicular to the Sloper (0 to 180 degrees). I have 2 questions: Can I run both antennas off the same 25 foot mast and (2) will I run the risk of signal cancellation due to the proximity of the radiating elements?
Ok, maybe a third question....would I be better off using a vertical for the FRG at the top of the mast?
I appreciate any help on this, everyone.
Thanks,
Don
Thanks,
Don
