BCDx36HP v1.24.00 Public Beta
UPMan
In Memoriam
Arlington, TX
http://info.uniden.com/twiki/pub/PartnerWeb/BCD436HPBeta/BCDx36HP_V1_24_00.zip
To install, unzip the above linked file. Then, copy the appropriate file (based on name) to the scanner's firmware directory.
Release Notes:
1. Modified the TGID check method on voice channel grants for DMR systems
2. Modified the voice channel termination method for P16 systems
3. Changed the operation of squelch backlight control
4. Fixed several minor bugs
vocoder
Indiana
This is the first time i did beta to these scanners, 436s 536s
Does it change firmware version in settings?
vocoder
Indiana
Ver did not change. Version has changed in the past with firmware ver 23
Hmm
Beta?
vocoder
Indiana
did it successfully update, i just did it for the SDS and it changed
Based on past updates, i am going to say no
In the past, it said something to the effect of successful and changed in settings
I did double check scanner sd, .bin file is there in firmware dir
vocoder
Indiana
Well darned
Checksum error
When i first started, there was no .bin file in there even though scanner showed ver 23 in settings
garys
Installed it on my 436HP & 536HP, no problem. Shows ver. 1.24.0.
sallen07
Rochester, NY
Well darned
Checksum error
Once a new firmware file is installed, it disappears from that directory. The fact that it's still there (along with the error message) says there was a problem installing it.
I would suggest you try downloading, unzipping, and copying it over again.
K9JLR
McDonough County, IL
Hmm
Beta?
You probably loaded the wrong version, as I did initially. The firmware download includes two separate files - one for the 436hp and one for the 536 hp. If you do not load the correct file for the scanner, it will still display version 23. Go back and make sure you pulled the correct file for whichever scanner you are updating.
pinballwiz86
Missouri
Beta firmware installed painlessly on my 436 and 536.
I love the "Open Squelch" backlight display option! Thanks Uniden!
allend
Long Beach, CA
Best words of advice if you radio is not having any issues for now do not open the can of worms on your radio.
Wait on any firmware upgrades until fully tested and released. Play at your own risk
