Folks,
There is an LTR trunked system listed in the database for Cleveland Browns Stadium on UHF.
https://www.radioreference.com/apps/db/?sid=5425
1. I don't believe this has ever been confirmed active as an LTR system
2. There are no talkgroups listed
3. There have been no submissions to the system
4. The license indicates DMR emissions
The note on the system says it was going to be an LTR system to replace 900 Mhz Type II system -- but I have to ask who in their right mind would have replaced a Motorola Type II system with an LTR system.
So, I suspect that IF there is a trunked system online using the frequencies from this license, it is likely going to be a DMR system. But theoretically I guess it could be LTR. One would think though that if it had been an LTR system people would have already programmed it in based upon DB information and would have discovered / submitted talkgroups.
The note on the system in the DB also says it si a low power system. It's licensed for 100w though. Of course, if it is active, I doubt it's on a tower somewhere in the city -- It's probably a the stadium somewhere and would likely have somewhat limited range.
At any rate, if you are within earshot and have the ability to program this system in your scanner as both an LTR System and again as a DMR Trunked system, please do this and let us know what you find. Of course if you are familiar with DSDPlus and know how to use it, that would be an even better option.
License: WQFH480
Frequencies:
451.9125
452.3000
453.0125
461.4875
461.6375
462.45
463.3125
463.5125
463.5625
463.8625
464.025
464.4625
If you are absolutely positive that there is NO system online, LTR or DMR, please report here. If you can confirm that it IS online as either an LTR or DMR system, please submit all relevant information to the existing system in the DB. If you find it is DMR and submit the DMR details to the system, we will build out a brand new entry in the database for it and then deprecate the old one.
License: WQFH480
Frequencies:
451.9125
452.3000
453.0125
461.4875
461.6375
462.45
463.3125
463.5125
463.5625
463.8625
464.025
464.4625
