You want just the DG. So KPG-95DG v7.01. If you load any dat file into 95DGN, it will find all Wideband channels and convert them to Narrowband. So don't touch anything with the 95DGN program.
Your wide/narrow selection will be per Personality, under Channel Spacing. Select between 12.5 and 25kHz.
However, DGN will correctly allow you to enter 2m amateur frequencies with 25kHz bandwidth. And if you mark a Personality as Receive Only, then any frequency can be marked as 12.5 or 25 and the radio will adjust accordingly, i.e. your volume will be equal. So if you truly are programming receive only on the Marine, MURS and NOAA or other wideband channel, then 95DGN will work for you.
