DeepBlue
Hello all. Anyone still seeing anything in the Digital Data Display area when it is turned on for digital transmissions? I swear I saw it and even have a photograph of it working on the local DMR and DSTAR repeaters as well as some info on the local P25 systems but now, I just realized, apparently aftert the last update I can see nothing in the small data area assigned to that function and yes, it's on for every memory dealing with digital.
Anyone still seeing info in the Data area and if so, what firmware versions are you using? I will try to go backward tonight on the firmware versions to see if that picks it up again.
Thanks,
Sean
Thanks,
Sean
