I’m assuming this is a trunked system the deputies were on? If that’s the case their talk around channels are more than likely the standard mutual aid frequencies; 8CALL90, 8TAC91, & etc. If it’s not any of those than look for any public safety conventional licenses under the same licensee for the trunking system, wether it’s the county or the Sheriff’s Office. Then try scanning those frequencies. It’s also a possibility that when they said switch to talk around, they were actually referring to just another channel “talk group” on the system. Instead of an actual simplex channel separate from the trunking system.
On another note, I’m also assuming they’re using the APX line of radios from Motorola which are dual / all band radios. So this means that this “talk around” channel we’re look for might be UHF or VHF if it’s indeed a simplex frequency they’re talking about. It would be a smart idea to put a couple of UHF or VHF simplex frequencies in their radios for actual talk around channels being that it would work much better than using a 700/800 MHz frequency for simplex operations.
- Dawson Adams
K4DPA / WQPN413
