My pro 106 will not pick up Minneapolis Fire but my WS1040 does just fine anyone have any ideas on why this maybe happening.I live in MN and use a 800MhZ antenna on both scanners.I use them both at home.
Thanks in advance
scott
Are they programmed
exactly the same? If your 106 is hearing everything
but Minneapolis FD, then it's likely that system got accidentally locked out, or the scanlist it's in is not being scanned.
If you are using software, either reload your file to the Pro-106, or use the software to "read" your WS1040 into software, then write that into your Pro-106. That way, they would be programmed exactly the same.
