- Joined
- Feb 20, 2003
- Messages
- 1,162
Will the Whistler TRX-1 work with Unitrunker?
You could always give it a try.looks like the webpage was last updated 2015. Since Unitrunker works for the GRE 800, might work for the TRX-1.
Unitrunker worked just fine with my WS-1088 when I got it a couple years ago... no reason it shouldn't work with a TRX-1.
Unitrunker should automatically switch it into CC-Dump mode. Park the scanner on an unused TG so the CC data is not interrupted. Should work fine.
Will you please explain how to set up the receiver when using TRX-1?
Sorry this took so long... yes, I'm using UniTrunker with my TRX-1 as we speak.
Of course you can also use the IF/headphone method as well.
- Connect your (powered off) TRX to your PC... wait, and make sure they're communicating (set the scanner time to PC time in EZScan).
- Once you're sure they're communicating, check Device Manager for the Com port they're using.
- Turn on the scanner, set PC/IF CC Dump on, park on an unused TG, then run UniTrunker.
- Click the + sign to add a new receiver, select WS1080, set the Com port from Device Manager, 9600, 8, 1, none.
- Boom, done... a new window should open and you'll see the traffic activity.
