Tech info for Anytone D868UV, Btech 6x2 & Radioddity GD-77
nd5y
Wichita Falls, TX
I had not seen high resolution photos of the insides of those radios before. I noticed that the pcb photos in both links showed that the DMR radios also have the AT1846S chip which is the same chip that the UV-5R type radios use.
prcguy
The D868UV is a very good performing radio, better than most so they must be doing something different than Baofeng.
mitaux8030
Silent Key
Home
Think of the AT1846S as the engine of a radio.
The UV-5R has this engine bolted to a very rudimentary chassis, no gearbox or suspension to speak of and a really cheap set of tyres. As a result, the performance of this combination is ho-hum.
A bit of a step up is the GD-77. A better chassis, perhaps a better set of tyres.
Going whole hog is the D868UV. It's got a great chassis, a gearbox and suspension and some really good rubber.
The GD-77 uses a better pair of low noise receive pre-amps than the ubiquitous UV-5R, and a better design bandpass filter.
The D868 pulls out all the tricks: better bandpass filters, in addition to a four stage varactor track tuned front end each for VHF & UHF, as well as evidence of some audio DSP'ing going on. Curiously though, they use a 20 year old 2SC3356 mid-gain class preamp design. There's much better devices available these days, so wonder why they went that way? Perhaps the 3356 has better compression margins? Whatever the reason, it's a really good receiver for a direct conversion design, as good as it gets.
