apx8500 mobile
esu78
HQ Westchester County NY
is there an antenna solution with 3 ports for the multiplexer ?
seeking a one antenna solution if at all possible
One Antenna with 3 ports ----> V/U/7 Multiplexer --- to 1 antenna connection to radio.
Thank you
John
Mr_Boh
The Land of Pleasant Living
Confused. Are you looking for the multiplexer part number, or a triband antenna? There are several triband antenna options that use a single connector, so you don’t even need the multiplexer/multicoupler
crazyboy
NJ
I’m confused, if you are seeking a one antenna solution just connect an all band antenna to the antenna port on the transceiver.
esu78
Mr_Boh
crazyboy
sorry-
So yes, I am looking for a tri-band antenna- that will plug directly into the radio w/o the Multiplexer if avail
I also do have the multiplexer on hand - if I need.... but it sounds like i may not ?
let me know what your thinking... or any recommendations
thank you for your help
Mr_Boh
Project25_MASTR
Millennial Graying OBT Guy
Texas
No need to have the multiplexer. Several options are available. Here's a few:
Panroma Antennas. Just pick your base. They even have an adapter to go to an NMO mount, or you can mount it to something like the Sharkee that also does LTE/WiFi/GPS
PCTEL
Laird
Larsen - seems to be the popular one around us
With the exception of the Panorama that uses a slightly different mount unless you get the NMO adapter, these all use a single NMO base with a single wire.
The PCTEL is what actually ships with the radios.
davo51
Planet Earth
I use the PCTEL from Solid Signal and it works great with my 8500, it also covers the VHF ham bands, which some tri-band antennas do not. So far good results with this antenna and the 8500
Mr_Boh
Another good one popular around here is the Sti-Co Tri-Band. There is a flexi-whip version of this too, have seen it, have touched it, just a pain in the rear to find someone who can get it. TESSCO rep couldn't find it.... Part number is RFMT-NT-V/U/C
APX7500X2
NY/CT
We have the Sti-Co and they work great, Our local Motorola dealer can't keep them in stock, Everyone is using them for the 8500 and scanner antennas.
They work great for both and they flex...They also make a glass mount version
