That's not correct, you measure the SNR to determine the sensitivity, the standard measurements for NFM are to measure the microvolts of RF required for 12dB SINAD (Signal+Noise+Distortion divided by Noise+Distortion) and for AM 10dB S/N ratio.
Another important spec is the SFDR, spurious free dynamic range, anything can be sensitive but if it overloads easilty it won't matter how sensitive it is.
The SDS100 has a cheap sattv tuner like a $10 dongle, they are designed for 6-8 MHz bandwidth DVB reception where signals are normally moderate strength and relatively constant. If you turn the gain up too much the in band intercept points fall through the floor and it will overload like hell, if you keep the gain too low it will appear deaf. Its difficult with AGC to get the gain right, it really needs to be user adjustable like a dongle. This is probably why Uniden won't publish a spec becuase they haven't finished fiddling around with it.
These cheap tuners make mediocre cheap receivers, Rafael Micro are known to have wide variations and poor yields which you can get away with when buidling a $20 satellite receiver.
