NYS DHSES
MegaHertz315
Central/Upstate NY
DHSES/OEM Maybe try these? Honestly, can't say as if I've ever heard them
45.1600- Statewide/R2
45.4400- Statewide
45.2800- R2
45.3200- R2
45.4000- R2
(KNNQ472) It's worth putting these in too (never know what you might hear):
853.5125 OEM- repeater/simplex
852.3125 OEM- temporary repeater/vehicular repeater
852.6250 OEM- mobile/vehicular repeater
852.6500 OEM- mobile/vehicular repeater
852.6750 OEM- mobile/vehicular repeater
852.7500 OEM- mobile/vehicular repeater
853.8625 OEM- mobile/vehicular repeater
853.8875 OEM- mobile/vehicular repeater
853.9125 OEM- mobile/vehicular repeater
853.9875 OEM- mobile/vehicular repeater
62Truck
Ordinary Subscriber
Uranus
Any ideas if the OFPC uses any of the 800MHz frequencies?
Anything is possible. Your best bet is to program them and see if you hear any chatter. I've seen some OFPC personal with the Multi Band Harris Unity.
radioman2001
New York North Carolina and all points in between
Quote"
Per my info all the unity radios have been recalled due to the fact they are too complicated for user to use efficiently. Not my words, but of some director who then ordered several hundred APX-8000's. Also from my info they operate on the local agencies channels too.
62Truck
Ordinary Subscriber
Uranus
Quote"
There are still some Unity's floating around in the field, along with some Kenwood 5200's.
ak716
'Merica
two support both of the last post:
A friend of mine works for OFPC, he said basically the same, however, recently was issued a Harris because they didn't have enough APX 8000's to go around at the time. He said the Harris's are too complicated for a lot of the guys to use
Now, on the other side.... I see SP with both APX's and Unity's, not sure the rhyme or reason there.
62Truck
Ordinary Subscriber
Uranus
It depends on the Troop. I know Troop T is using APX and I think G is as well. I was talking to a friend of mine who is a Sgt. for NYSP, he was telling me they are going to Kenwoods in the mobiles some time soon. One head, three decks, one for VHF, UHF and 7/800 Mhz.
GTR8000
NY/NJ Database Guy
BEE00
98% of Troop F are issued Harris portables. The notable exception is SP Haverstraw, who are issued APX 7000 VHF/7/8 portables on Rockland's system.
medic190
Stuyvesant, NY
NYS OFPC
DHSES is transitioning away from the Harris XGP100 Unity portables to the Motorola APX8000 portables. Units are being handed out and Harris are being collected. They are not being 'recalled' due to complicated use, rather the firmware does not allow proper programming of the various trunked systems anymore... The portables are programmed with as many local channels as the end user (County / City / Town...) allow...
NYSP also have many Harris Unity radios and are running into the same issue, so I'd expect a transition to the APX's for them as well....
To answer the OP's question; OFPC uses 45.56 (OFPC channel) in lowband primarily while mobile. You may also hear them on the DHSES lowband regional repeaters, but not on a regular basis. Ofpc does not operate on the State regional OEM frequencies as a normal point and normally are not on 800 frequencies... While more 'local' you may hear them on the VHF frequencies assigned to NYTF2 153.770 or 153.830. On a rare occasion, they might be on DHSES encrypted channel.
