Mr_Boh
Picture says it all:
Yea, I'd certainly think twice (and more) before walking away from the Harris system after spending $25M+ on it. But it has happened, and agencies have been able to recover some fraction of its cost. Apparently they've had several complete failures of their simulcast site - which is all of the towers. This is what the FiRST rep was getting at. Since STMC would have coverage from adjoining FiRST sites and at least one ASR in-county, they would not lose comms if the FiRST STMC simulcast site went down, they'd experience some degradation except for down by Point Lookout. Filling out coverage with additional ASRs would improve coverage to in-building specs, and maintain coverage down south in case of a simulcast failure.It was a slightly confusing and long meeting. But it definitely seemed the main topic of the meeting was supposed to be about becoming an interoperable user. Then the discussion of the radio issues that they have been having changed into a discussion of becoming a primary user.
My guess is that they will apply to become a primary user in December even if they aren't 100% sure they are going to switch to FiRST.
I bet that they will stick with their current system and then will use MD Tac Channels if and when they have issues with the system. My assumption is that they won't want to spend the millions to add multiple additional sites.
None of this bodes well for Worcester given - if I recall correctly - St. Mary's has 13 towers and Worcester only has 6....(plus 3 OC system towers). Of course, no two areas or systems are the same.
I was in Worcester/OC Tuesday and Wednesday and believe I heard unit multiple times reporting coverage issues requesting they be added to the logs.
