I've been looking around for the answer to a simple question. What data interface is used to connect a GPS with the SDS100?
I have looked at the Uniden solutions:
GPS:
https://www.uniden.com/shop/communication/serial-gps-receiver/
...and the cable:
https://www.uniden.com/shop/communication/gps-usb-cable/
Back in the "old days", this is how Uniden showed connecting a GPS to a scanner:
ConnectingAGpsReceiver < UnidenMan4 < TWiki
...the GPS show in the diagram used a serial interface that was connected to a DB9 connector. We needed a simple cable to route the serial signal from the GPS into the proprietary connectors on our radios.
I have a similar Garmin GPS that I'd like to see if I could press into service for my SDS100, and just like the picture, it has a serial interface that is presented in a DB9 connector. The specific model is a GPS18x PC:
https://buy.garmin.com/en-US/US/p/27594
Now I see the Uniden GPS adapter cable accepts a din connector and presents it to the SDS100 via a miniUSB. Is it simply routing the serial signal to a specific pin? Or is there some sort of serial to USB conversion embedded somewhere inside the cable?
Anyway, thanks for reading this far. I may forget all of this and just get the GPS cable and another GPS from Amazon. They have a model for $30 that appears to work with Uniden. Anyone else try this out?
https://www.amazon.com/GlobalSat-BR...TF8&qid=1537387400&sr=1-8&keywords=uniden+gps
GPS:
...and the cable:
