TRX-2 Long Squelch tail
Chronic
On some analog frequencies , even with ctcss on I am getting a very long squelch tail , in some cases 2 or 3 seconds , am I missing a setting somewhere that will make it go away ?
RoninJoliet
ILL
I get the same thing on a RS197 on VHF except when I install the "FM" trap in line it all clears up and the station even gets better.....
BrianG61UK
England
For me it's usually worse with CTCSS on than without it.
So I only use CTCSS when there is actually interference from something else that would come through without CTCSS.
dispatch235
Central Missouri
I don't know about the settings on the TRX2 but on the 1065 if I change the ctcss setting to "auto" it will get rid of the squelch tail.
hosehead88
Central PA
I have had the same problem since day one with my TRX-2 (x2) and my WS-1088. No adjustments to squelch or CTCSS have ever solved the problem. I stopped using them all for low band
mrkelso
NNJ
Same here, squelch tail is way to long on analog 155.700 no matter what you do to tweak it. Whistler should step up and tweak the firmware.
djeplett
NE Wisconsin
Or at least allow "Expert Settings" tweaks like on the PRO-106/PSR-500 scanner design. I had trouble with a squelch tail on a couple channels using DCS with those scanners, but adjustments to the expert settings virtually eliminated them.
No tweaks allowed with the TRX-1/TRX-2.
Ed6698
Evansville, Indiana
I wonder what is different as far as the WS1080 and 1095. I have both of them and have no squelch tail issues on any analog.
Wackyracer
I don't get any LONG squelch tails on my trx-2 and I have a tone of analog. I set my squelch to 9 or 10. I think they may be getting some sort of interference that only affects the trx.
marcotor
I ♥ÆS Ø
Sunny SoCal
I removed the 1095 in my vehicle, as the loooong tails on the CHP's low band system made it mostly unlistenable.
AKJohnny
Scanner Addict
Kendall County, IL
I only get the long squelch tails when mobile. When used stationary as a base station, all is fine. Whistler needs to test in a vehicle while driving or they may not see the severity of the problem. This happens on both my trx-1 and trx-2.
Ubbe
Stockholm, Sweden
It's probably not the squelch in itself that are the only problem causing squelch tails but also the bad front-end. It get interfered easily, particulary in VHF that reduces the noise level and the squelch doesn't close as easily. The amount of noise are used to control the squelch. Even without an antenna connected it seems to be a lower level of noise in VHF compared to UHF.
A modern car has a lot of electronic "smog" and my experiance are that it mostly appears in VHF and LO-VHF.
/Ubbe
Skypilot007
Medford, NJ
On my TRX-2 with the squelch set at 9 the squelch tail is acceptable but this setting of 9 sets the squelch threshold to high and weaker transmissions that I want to hear are squelched out. Dropping the squelch down to 8 or 7 brings on the long squelch tail problem.
I too have reported this to the whistler many months ago and nothing has been done. :mad:
APX7500X2
NY/CT
This is the reason my TRX-2 is in my basement, I got it to put in my truck with the remote head but the squelch tail drives me nuts, I have tried every diffrent setting for squelch and fine if i put no delay its the best but still gives tail, If i do 2 second delay like I want its not woth lisrtening to
lolbananalol2
Newcastle, New South Wales, Australia
What do the delay settings do?
