When I reinstalled my scanner sd card files where converted to .HPD.
What do you mean by "reinstalled" the SD card?
Did you replace the card with a new one?
Did you reformat the card?
Did you use the Clear User Data function?
There is nothing in the scanner or the Sentinel software that could possibly convert a .wav file into a .hpd file.
Where on the card are the .hpd files you are seeing? Are you saying that the .hpd files are in one of the audio sub folders on the card? Or are they in the HPDB and favorites_lists (if you have created any favorites lists) folder?
As UPMan posted, any recording files would be .wav files in one of the two Audio sub folders on the card. If they are not there, they are gone. Did you transfer them to your computer?
If there are no .wav files in the Audio sub folders, they have either been moved, deleted, or the card has become corrupt.
The .hpd files are database files in plain text format. If you open one of the .hpd files on the card in a text editor (don't make any changes to it), you will see that they contain only database information.
