SDS100/SDS200: Firmware 1.06.00M Public Beta
UPMan
In Memoriam
Arlington, TX
Release Notes:
1. Fixed freezing issue over 1000 sessions (sub folders) in user recording mode. This might also affect the reboot issue.
2. Support decoding for Late Entry code of CapMax.
3. Modified operations of LCN Finder for CapMax.
4. Modified DMR TGID validation method.
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/SDS100-1.06.00M-1.01.05S.zip
To apply:
1. Connect the scanner in Mass Storage mode.
2. Unzip the above linked file and copy the filesto the scanner's \BCDx36HP\firmware folder.*
3. Disconnect the scanner from the PC.
* Note that there is no change to the Sub firmware in this version. If your scanner already has Sub firmware v1.01.05, you can copy just the Main 1.25.00 firmware in Step 2.
sallen07
Rochester, NY
Version number wrong?
Thanks Paul!
But did the 436/536 version number get misapplied to the thread and zip file name? They both reference 1.25.00 but the actual firmware version is 1.06.00 ....
enosjones
Price, Utah
Can I clarify the model this is for? when I saw the 1.25.00 firmware I thought it was for the x36 scanners, but I open it up and it says sds100, 1.06.00 bin and sub v 1.01.05 firm
UPMan
In Memoriam
Arlington, TX
Try it again.
Per the model tagged in the main subject, this version is for the SDS100.
WX4JCW
Stow, Ohio
heres a screenshot of the zip file
ColonelMike
Shepherdsville, KY
I get a 404 error now on the link
EDIT: the link needs to be changed to a zero in front of the 6 instead of a dash. Downloading now.
racing1
Also fixed the subject.
I get this error when I click on the link.
