TOP2
I'm having a problem reading/writing to my TRX-1 using the supplied cable. I had purchase a second cable and it's not working either. I tried using a different computer and the same result. I can write to the SD card by directly inserting it in a computer and update the data that way. I've looked in scanner but may have missed it is there a lock that would prevent a read/write to the scanner directly?
I wonder if the connector on the scanner is the problem.
Thanks for any help.
Mike
Mike
