I'll be installing a pair of antennas in the attic (a discone to attach to an rtl-sdr, and a DBJ-1 to attach to my dual band radio). I will run LMR-400 from the antennas, out the attic wall, down the side of the house, and back through the wall into my shack, terminating at a pair of N female connectors on a wall plate. I'm aware of the need for drip loops. The total length of the cable run is going to be less than 50'.
For passing through the exterior wall, I'll be drilling 2" holes and fitting them with a PVC pipe with an elbow on the end, sealing that in with great stuff spray foam, then stuffing the inside with insulation after passing the cables through.
Inside the shack, I'm planning on running LMR-240 from the wall plate to my equipment (I wanted something more flexible than the LMR-400 inside the room).
Does this seem like a reasonable plan?
