- Joined
- Jul 19, 2004
- Messages
- 283
My SDS100 has stopped charging. Neither the red light or green light will come on. I double checked my settings and the battery charge is set to enabled. Has anyone else experienced this?
Make sure you are not accidentally plugging into the Micro USB connector as it won't charge there. Also try a different Mini USB cable and USB charger (1 Amp min). If nothing changes, try charging with the scanner off.
A few others have reported this issue. It sounds like it needs to be sent in for repair.
https://forums.radioreference.com/uniden-tech-support/373442-sds100-stopped-charging.html
If it is UNDER 30 days, return it for a full refund or get it replaced. And call your credit card company as they will debit the vendor. My best advise to you. Best of luck dhmann1811.I appreciate your suggestions. I have tried all of them to no avail. It is still not charging correctly and I can not get the green and/or red light to work (it use to work fine). Guess I need to call Uniden as it appears I’m the only person having this issue.
No. It's not.. You have to enable that. Menu/Settings/Battery Options/Set Charge While On
If you were to end up having an issue in that 13th month, I would recommend contacting our support team. While our warranty policies are set, there are circumstances where we can look into discretionary exceptions. This is hypothetical at this point and I doubt it will be an issue.I was very disappointed that my SDS-100 started shutting down without a low battery warning. I plugged it in to the supplied charger and now it hums with any 5 volt supply and refuses to start. It has been sent back after owning it only two weeks. Now I am told that I lose the additional warranty time while Uniden has it for a month, my warranty will not be extended while I had to pay for shipping and insurance.
I'm very sorry to hear this. It's up to you if you would prefer a refund, but warranty repair is also an option for you, and if you are in the return window through your retailer, an exchange may still be an option through them.Not to pile on but I'll do it anyway. I just received my SDS100 yesterday and it won't charge the battery either, whether turned on or not. It will occasionally read about 3 volts on the display then go to nothing. Yes I am using the bottom mini port, I tried different 2amp chargers and cables, yes it is set to charge when on but it won't charge whether scanner is on or off. I get an occasional red blink and it will even randomly give me a green light indicating it's charged but it still won't turn on under battery power only. I guess the battery or charging circuit is just DOA. Seemed like a good radio for the few hours I spent programming it but it's going back for a refund. Grrrr
Yeah I owned it for less than 24 hours so I am getting an exchange through the retailer. Thanks for the response.I'm very sorry to hear this. It's up to you if you would prefer a refund, but warranty repair is also an option for you, and if you are in the return window through your retailer, an exchange may still be an option through them.
