Ottawa P25 P2 (new topic)
VA3JPX
Ottawa, Ontario
Hello Folks,
I host the Ottawa Fire Services feed on Broadcastify.
Again, I am noticing missing transmissions. This has happened before, but was rectified when the DB was updated. It has surfaced again.
For example:
1. pump 41, dispatch
2. nothing
3. dispatch, message received
or
1. pump 51 dispatch
2. nothing
3. pump 51 back in station
4. dispatch: msg received
Are there new frequencies that have not been added to the DB? I have no way of knowing or testing.
Ideas?
James
VA3JPX
Ottawa, Ontario
is your scanner on i.d search mode
As I provide the Ottawa Fire Services feed, I have not tried this. As I understand (correct me if I am wrong), but the scanner would pass the new TG's that it would pickup in ID search mode - to my radio reference feed. I do not now how to prevent this from happening. All I want to achieve is finding out what those (if any) new frequencies are. I suppose I could camp on the control channel and run pro96.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Asking if he's in ID search mode compared to ID scan mode has nothing to do with the question he was asking.
He was asking if their was any more frequencies added to the system due to the fact that he was missing pieces of transmissions. Talk group transmissions don't hop around. The frequencies within the system however do. So yes there is a possibility that more frequencies have been added and therefore if you don't have them programmed then yes you would miss some of those transmissions.
I have a feeling there might be some new frequencies but I'm unable to confirm.
I was in Arnprior the other day and was able to listen to this system fine. But yet I too noticed some transmissions missing also. Now I'm not sure if it was due to the signal itself being recieved or if it was because of missing frequencies in my programming. But I did have the same thing happen as well.
If anyone out there is able to capture all frequencies from the system to confirm that would be great. Perhaps there is an update that needs to be put out there.
VA3JPX
Ottawa, Ontario
Thanks for the reply. Is their any way I could try capturing the frequencies? I was running Pro96 software, but it only displays the frequencies that are already programmed into the scanner. Is there a way to use Pro96 to capture new frequencies?
Thanks again.
randyf
still trying to figure this all out
campbellford ontario canada
I Was Thinking if new talk groups were added vs frequencys this would help i thought talk groups would be added in first
IdleMonitor
You could try using an SDR to get new frequencies if you have that. Otherwise I don't know.
IdleMonitor
While that may be true to an extent. The question however was regarding missing frequencies as opposed to missing talkgroups.
There's plenty of talkgroups part of this system currently but it's a matter of identifying users and unknown talkgroups.
Best way to help with that is. If you have the capability of having radio IDs then you can use those to your benefit. Once you've established who a user is. Ex. Fire chatter vs Bus chatter. Finding new talkgroups with those identified radio ID users should help if those users use multiple talkgroups. Both identified and unidentified.
mciupa
Moderator
Thanks again.
Have you tried Unitrunker?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
What scanner are you using? Most newer scanners use control channel only mode and use the system's bandplan to find the voice frequencies. If you have one of these scanners, missing voice frequencies isn't your problem.
DaveH
Ottawa, Ont.
Still not sure what is causing your problem James.
Refresh my memory: is your stream setup capable of CC-only? Are you using Site 1 (west) or Site 2.
If there are missing frequencies, Unitrunker and Pro96com will find them as the P25 CC sends out the bandplan and channel numbers as assigned, all the info is there. If it doesn't, may be because it only displays them as the are used, so if they were not previously found/stored, and they are not assigned while the program is running, they will not show. (Or unless the version you are running is buggy, or somehow misconfigured in a way I can't think of).
Added frequencies could be new, or re-assigned from EDACS system for that site; have you checked those?
Dave
VA3JPX
Ottawa, Ontario
Here is the scoop on my setup:
Scanner: Uniden 996P2
Firmware: v1.07.09
Programming Software: FreeSCAN 2.18-beta6
Yes, control channel only is check marked. Also it is greyed out, so it cannot be changed.
I am monitoring Site 2 exclusively.
Please see the attached photo.
Thanks for any help you can provide.
DaveH
Ottawa, Ont.
Seems the last time this came up you were having problem with CC decode on Site 2 due to your location. I suggest: run Pro96Com parked on the CC (if it is scanning, activity will disrupt this test). Watch the signal decoding quality bar-graph at the lower left of screen. If it jumps around a lot or drops out, you will see it.
Dave
