Sr. Citizen with sw Antenna Question
BOBRR
Boston, MA
Hello,
Do sw listening below 30 MHz.
It is unfortunately not practical to run a long-wire antenna outside, or anything in an attic.
I can, of course, run a wire around three or four walls in my study where
my receiver is, but was wondering:
Many years since I've researched this:
Is there available these days any "compact" receive only antenna that one might
keep on their desk that is not too big, and works (very) well for frequencies below 30 MHz ?
Cost would have to be below around $ 50 perhaps.
Thanks, appreciate the help,
Bob
ecps92
Taxachusetts
YMMV as to how effective it is, but looks avail in Tax Free NH
https://www.hamradio.com/detail.cfm?pid=H0-008248
Hello,
Bob
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you have a good junk box and am not afraid to build something, I'd suggest this - I used this a few years back and it was pretty effective...
The Carpet Loop -- antenna special on hard-core-dx.com
And something else I built, altho using it with a good transmatch is a very good idea...
The McGyver(tm) special - The RadioReference Wiki
Keep in mind that indoor antennas are seriously compromised by all the nearby noise sources as well as attenuation from the building itself (in some cases). Any decent outdoor antenna will perform better than an indoor one, but these 2 worked pretty well for me. The beauty of both of these is that you can make them as large or small as you need. Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
A small caution here - you will notice that the schematic for the Carpet Loop tuner has 2 diodes across one of its ports. This is for static protection, but in some cases, like the project shown elsewhere, under certain high RF conditions, these could conduct and start causing noise all over the place. You can substitute other things in its place, such as a small gas discharge tube, a small light bulb from a flashlight, or just remove the diodes entirely
Mike
majoco
Stirrer
New Zealand
The Degen 31MS loop has got some good write-ups - I have one on order - available from Aliexpress.com or anon-co.com - less than US$20
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I think - I could be wrong here - that Bob is using a WinRadio. Not that these little antennas like the Degen or the wind up wouldn't work - they likely would - but skimping on the antenna when you are using a world class radio just shoots you in the foot. The results aren't likely to be all that good.
If it were me, I'd be looking at the LVP loops, but his budget is real tight...Mike
