And just as a side question, maybe you would know. Are there any plans for professional radio to venture into Gigahertz territory?
For mobile/portable two way radio?
Yes, but not like you are familiar with. Think cellular style broadband services. It's not channelized like standard LMR radio systems, but broadband like LTE.
For most two way portable/mobile radio, 900MHz is where most of the traditional radio services pretty much stop.
As for 700, 800, 900, building penetration is a big bonus. Getting signals into reinforced concrete buildings with low-E energy efficient glass can be difficult. Higher frequencies penetrate better.
Spectrum availability is an issue in larger metropolitan areas. One issue with VHF is non-standardized repeater in/out splits, which can make getting a bunch of VHF frequency pairs that can work together well difficult. UHF, with the standardized 5MHz split is a bit easier. When you get up into 700, 800 and 900, standardized wide spaced repeater in/out splits are the rule, and that works well with multichannel trunked systems where you need to combine a bunch of repeaters into one antenna systems.
But, yeah, a lot of areas could do better with VHF or UHF.
As for low band, noise floor becomes an issue, as well as skip. Then there's the issue with efficient antennas on portable radios.
