BCT15X Picking up half of the transmissions of my local PD EDACS system.
deeroc417
New Paltz, New York
Hello, I am fairly new to scanning, but I do know how to program ect. So basically I have my BCT15X programmed to scan my local Pd, everything is programmed correctly. The thing is when I listen for example dispatch could call the call sign of a a unit, then it waits 30 seconds and the dispatch says “received” and I miss the transmission beewtwn the officer and dispatcher deeming the scanner pointless. Sometimes I catch it sometimes I don’t. I have a aftermarket good antenna and have full bars. It’s only on the EDACS channels this happens. On conventional channels I get whole transmissions. My squelch is set to 2. I don’t know why this is and would like to get the whole conversation on the transmissions. Sorry I I worded this confusingly, don’t really know how to explain it otherwise. Thank you in advance.
wtp
Port Charlotte FL
i see two tower in ulster
could it be that they hit one tower and you have the other one ?
or do you have both towers in ?
you could also check the settings on the systems.
hold should be at 2
delay should be at 0
they are two different things.
Ubbe
Stockholm, Sweden
It could be some problem with patched TG's that the BCT15x can't handle properly?
I haven't had an EDACS system since 15 years back but at that time there was a computer decoding program that decoded the control channel so that you could see what was really happening while the scanner where trying to follow the conversations.
/Ubbe
deeroc417
New Paltz, New York
They may be using AEGIS or ProVoice as well which is digital and beyond the capability of your scanner.
Upon further review I noticed my county is indeed using EDACS along with AEGIS. Guess that explains why I sometimes only hear half the story. Thank you for the reply and information. I guess I’ll wait for them to go full digital and then purchase a digital scanner.
wtp
Port Charlotte FL
ok
i don't know but could it be that they are on the other tower and the base could be transmitting on its home tower and the satellite tower ? but you would need to hear both to answer this.
also delay set to 2 and hold set to 0
they are not the same thing.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There are no scanners that can handle AEGIS so don't hold your breath to see if someone makes one...Mike
