CNYICC Oswego P25 Data Services?
DSheirer
Fulton, NY
Does anyone know what data services Oswego City/County may be using over the CNYICC P25 network?
There's a continuous stream of UDP/IP data packets using port 231 that the network is sending out to the radios. They're also using Motorola's Automatic Registration Services (ARS), so this may be some type of data network overlay service.
Denny
studgeman
Denny, I have seen the stream on Madison County too. So I am not sure it is actually Oswego County. Could be something AMR is doing?
I have some inside contacts I will see what I can find out but it might be some time.
DSheirer
Fulton, NY
Would that be the AVL or GPS service ...?
Possibly, but they're using Motorola's ARS service, like what is used with MotoTRBO DMR, so I would have anticipated seeing LRRP style GPS messages.
I ran the decoder a bit more and the messages are going to a variety of mobiles: Oswego City (850xxx), Oswego County (860xxx), NYSP Troop D (894xxx), a Madison county radio (700702).
The message format appears to be some form of fixed-length status messaging.
Code:
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD005000000000921DAE35810000C3
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD000800000000921D0EB68000005B
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD000C00000000921D0EDE80000087
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001500000000921D0E4E81000001
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001800000000921D2EB68000008B
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001900000000921D2EBE80000094
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001A00000000921D2EC68000009D
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001B00000000921D2ECE800000A6
NAC:672 IPPKT LLID:700702 IP FROM:10.9.8.248 TO:10.173.192.29 UDP FROM:231 TO:231 PACKET:4D4347500482230A00008779D0DD001C00000000921D2ED6800000AF
Denny
gutter89
Williamstown ny
When they Did the Radio System Change from 800 to CNYICC they added AVL Units that ran through the radio in to County Owned Vehicles and other agencies
