Thanks...I saw some of it a bit back before I made this one, but thread got cluttered and drifted off.
Still don't believe you can do anything with logging or retrieving with icom's software. Also didn't see mention of auto memory write channel access, editing and transferring with the icom software.
Grabbed RT Systems' software and did what I wanted to do within minutes as expected. Except of course for logging which they really don't. BuTel's clunky import/export feature will keep me from using it unless they add logging (and control) like their other models.
The Android RS-R30A is pretty much just a control application with very limited settings to edit. In case anyone is wondering, audio is not streamed to it which would have been a bonus...too bad you can't hear audio from up to around 30 ft. away. Better crank up the speaker and annoy others around you.
The RT Systems software also doesn't delve too deep into all the settings so you still have to use the radio to edit the majority of its settings.
Perhaps you have to shell out $80 for icom's software to do that but still need verification from others that it will actually let you modify
ALL settings on the radio from the software.
