M7100 high power to dash mount?
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Picked up VHF M7100 for cheap recently.
However, it's the high(er) power version which only comes as a remote mount configuration, due to the chances of heat buildup in a front mount configuration.
I know that converting an M7100 remote mount to a dash mount is relatively easily done (I've done it), and I'd like to make this one a front mount. It's going to be sitting on top of a desk and in the clear, so I'm really not worried about heat buildup, especially considering that it won't be transmitting a whole lot.
Harris does not recommend doing this conversion due to that heat buildup issue, but they don't actually say it can't be done. Does anybody know for sure if it can actually be done? I don't want to tear into it if there's no point; if not I'll just have to live with the radio unit on the floor under the desk and the control head on top (inconvenient, but not too much).
Tom
Radioman96p71
Yes, it can be done the exact same way the mid/low power units do. Same cables and such.
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
In both Orion and M7100 high-power radios (110 watt), it is common practice to convert them to 'front mount' configuration when mounting them on boats and in Forestry tractors/bulldozers.
The front mount bracket WILL support the heavier body, if six or more mounting screws are used into a solid surface.
You will also might require the following items:
  • Front Mount accessory cable (for speaker)
  • High power DC Power Cable (4 gauge) which should have come with a new radio. The standard low/mid power DC Power Cable is 10 gauge.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Thanks for the info.
Looks like I'll be doing a bit of surgery on my M7100....
