unusedusername
- Joined
- Aug 26, 2015
- Messages
- 87
Hello all,
We have a thread going on in the Uniden Tavern on entering ham repeaters into the RadioReference database. I'd like to ask a question about that specifically regarding DMR repeaters.
I have a few DMR repeaters nearby. I'd love to add them as single-frequency trunked systems, but there are some problems with that.
Ham radio DMR has about ~500 fixed talkgroups, but also has several thousand talkgroup IDs available for "pick up" or short term use groups. If I made a TGID to text string lookup table for those then I would be looking at ~5ish MB of text uncompressed for that lookup table. This table changes very rarely.
The ham DMR network has ~118,600 users across both systems, with each user having a DMR ID (number) that can be converted into an alphanumeric ham callsign. This lookup table is about 2MB of text uncompressed. This table changes weekly as more users are added to the system.
There are two different DMR ham radio systems that don't (usually) play nice with each other. They use different talkgroups between each system, however all the repeaters within a system share the same talkgroups.
A link to this data can be found at https://radioid.net/ if you ignore the site's badly configured ssl certificate.
Adding all that data to just a single repeater is far more then the 1mb limit for a single favorites list, so even if I were to get it into RR, it wouldn't fit into a Uniden Scanner.
Understanding that it isn't feasible to add the reality of the system into RR, how do folks suggest I add a usable subset of the data to the database so that it can be preloaded into my scanner on the next system update?
