Just curious what a good setting for the battery warning level is?
Sent from my iPhone using Tapatalk Pro
has Uniden shipped all the BIG replacement batteries to registered owners?
I’m at 3200 is this bad for the battery?
There was another thread about the setting where Paul stated the setting has nothing to do with when the scanner will power off, but rather when it will start alerting for low battery. No setting will harm the battery as the radio will power off before that happens.
It's not "bad", it's perfectly fine. You can extend the life of Li-ion batteries to some extent by limiting both the charge and discharge (e.g., never discharge past 3.4V and never charge past 4.0V), but, IMO, it doesn't buy you much. Not worth worrying about.
I'm not sure where you are obtaining your information, but you are incorrect. The SDS100 batteries are LiPO (lithium polymer), not Li-ion (lithium ion). LiPO batteries have a maximum charge voltage of 4.2v per cell and a minimum discharge voltage of 3.0v. I have used LiPO batteries for years in my electric RC airplanes and we in the RC flying hobby typically go by 3.2v per cell minimum voltage.
