I think I've discovered the root of a couple problems I'm having and would like for the more knowledgeable to confirm it.
In trying to figure out a Cap+ system I am using a RSPduo with SDRuno software as the CC signal source. For the VC following I use a RTL-SDR dongle which feeds FMP24.
In this setup DSD+ does not retrieve the network/site/frequencies from the appropriate files.
As a test I changed to the RTL-SDR dongle as the CC signal source and the network/site/frequencies was retrieved and displayed on the CC Event window.
So, in order for the Cap+ info to be retrieved I MUST use an RTL-SDR dongle as the CC signal source. Is that correct?
