Listening to Wireline
billyfromhill
Is there any good way to quickly and inexpensively check the wireline output from a tone panel? Can I just plug a old telephone handset into the wireline interface of my tone panel and listen to the received audio or is there some better way to do it without a tone remote?
Lineman's Test Set, AKA "Butt Set", if you don't need to check frequency or level. A standard analog telephone should work fine if you've got one laying around.
If you need to check frequency and level, look for an old "TIMS" set, (Transmission Impairment Measurement Set). You can usually pick them up used on e-Bay pretty cheap.
I carry one of these: https://www.ebay.com/itm/HP-4937A-T...:tV8AAOSwCTBbR8i3:sc:USPSPriority!95076!US!-1
krokus
Southeastern Michigan
If you are just checking for presence of signal, one of these might work for you.
https://www.homedepot.com/p/Sperry-Lan-WireTracker-Tone-and-Probe-Wire-Tracer-ET64220/202520187
https://www.homedepot.com/p/Extech-...rator-and-Amplifier-Probe-Kit-40180/205556907
Sent using Tapatalk
cmdrwill
So Cali
You could even use a high impedance head phone to bridge the line. Most 'wireline' circuits are 600 ohm impedance, so something like 2000 ohms impedance would bridge the line.
The mentioned butsets have a Bridging switch.
zz0468
Banned
Is there any good way to quickly and inexpensively check the wireline output from a tone panel? Can I just plug a old telephone handset into the wireline interface of my tone panel and listen to the received audio...
Yes, that will work. But it's not useful for making any measurements. You could simply hear the audio.
...or is there some better way to do it without a tone remote?
A transmission impairment measuring set (TIMS) is what you'd want. Used TIMS of various types are quite affordable from ebay.
kb4mdz
Cary, NC
The installed base of tone remote systems is still huge. Proper measurements and good discipline of levels is vital to proper operation. Yes, something that can both measure & generate tones is very important.
