Quality on Site 3 varies for me. Sometimes I can hear okay (but nowhere near what I really need), but other times, it's so bad that it's completely unusable. I bought an SDS100 last night from ScannerMaster and I assume it will be here next week sometime. Hopefully it will work for me.
The heat issue is interesting. I wonder why it would heat up close to the antenna area? Weird.
IIRC, the heat in that area is from the SDR chip used. That uses more current, than older designs. Someone else made a comparison of how warm their SDR dongle got when running one of the software packages.
It gets a little warm, but not what I'd call "hot", The 'waffle maker' that's been kicked around, on and off, in the Uniden Tavern, would not function with temperatures I've seen. Also, I've seen a few comments that the scanner seems to be running cooler (even if slightly so) with the larger battery as opposed to the early-adopter small battery. (I'm an early adopter.) I get somewhat the same impression.
I would also note that I am not seeing a problem with weak Vhf/Uhf reception. I know some owners have mentioned it, but I'm not seeing an issue at this time. Some of the ones that reported issues did send their units in for repair, and when receiving back either their repaired scanner, or in some cases a whole unit replacement, the problem was solved. I think that the wide ranging comments, from 'works very well', to 'it's deaf as a post', are more indicative of a larger than expected variance between individual units as opposed to a design flaw.
