mdc1200 radio kill codes
Mr_Observer
A "kill code" is not transmitted as a normal MDC data burst it is a unique data burst that can only be generated by a properly configured Centracomm class console and base station system. The data that is transmitted disables the radio in a way that will only allow it to be reactivated by the console that disabled it or the Motorola factory.
MR_O
7586
NY
radio kill and stun
At our HQ we have our base console and when we hear somebody whos not suppose to be on our frequency or If we have a member playing around on the radio we type in radio disable and and we look at the radio identifyer and we enter thier radio number and we hit stun or kill and they will not be able to use the radio at all if its killed or they will not be able to transmit at all *EVER* untill we enable thier radio again. Also with are units (cars/ambulances) we can disable them completly by the click of a mouse and lock you inside if your a thief :)
COOL ISNT IT
Astro25
Chicagoland
The MDC Stun/Kill option can generally only be transmitted from Dispatch Consoles - ie Centracom Consoles, and I'm not totally sure if current Zetron products support it or not, but I would not be suprised if they did. Typically, only the Console that "stunned" the radio can "un-stun" it, but if you force a matching 'good' codeplug from a good donor source radio, you can revive it. Not sure on newer radios such as the Waris and 2500/5k radios, but older first generation Astro radios are possible to revive.
cathoderay
South Carolina
try these opcodes within short MDC messages:
sun command = 0x2b0c
stun ack = 0x0b00
revive command = 2b0c
revive ack = 0x0b0c
command is sent to radio
ack is sent back by radio to confirm it worked
RKG
Boston, MA
MR_O
Not quite so. The Radio Inhibit and Radio Restore commands are in the same format as any other MDC sentence, with only the three-digit hex value changing.
That said, Motorola for obvious reasons doesn't encourage folks to be about to home brew these commands, and what the codes are is considered sort of proprietary. Just for the record, however, it is quite possible to program a Zetron paging encoder to send them.
car5le
Northwestern Montana
We use the Zetron ACOM system, and some of our other agencies use the Centracom. The ACOM system works just like the ACOM system with all of the Enhanced MDC features. There are several other companies out there that also do Enhanced MDC functions.
